If a group is not rotated I can compare bounds to local_bounds to see if user has scaled the group and by how much in x, y and z. ( I can do similar for component instances.)
This doesn’t work if the group has been rotated. How can I tell xscale, yscale and zscale for a rotated group?
Barry Milliken
tr=group.transformation.to_a
xscale = Math::sqrt(tr[0]*tr[0]+tr[1]*tr[1]+tr[2]*tr[2])
yscale = Math::sqrt(tr[4]*tr[4]+tr[5]*tr[5]+tr[6]*tr[6])
zscale = Math::sqrt(tr[8]*tr[8]+tr[9]*tr[9]+tr[10]*tr[10])
Wonderful! Now I want to apply new scale factors.in the group’s local x y and/or z direction.
PLAN A: steps
- transform the group by its inverse transform,
- use bounds to calculate pt at center of local XY bound.
- transform about center pt using new scale factors as ratios of the existing ones.
- apply original transform to get back to original position and rotation.
PLAN B
Use Pythagoras and trig to transform the group in place.
Which would you do?
Suggest PLAN A:
You don’t need to take the inverse if you use the following:
center = group.local_bounds.center
scaling = Geom::Transformation.scaling(center, xscale, yscale, zscale)
group.transformation = group.transformation * scaling
The “transformation=” assigns a rigid transformation. With the “scaling” variable last in the multiplication, the center position is in the group’s transformation’s local or intrinsic coordinates.
Note: If you really meant a Sketchup component instance, then the bounding box’s center is would be accessed through “entity.definition.bounds.center”.
Your inverse suggestion would work with an affine transformation:
group.transform! group.transformation * scaling * group.transformation.inverse
After the transformation update, Edit…Undo will undo the simple scaling, and Edit…Redo re-apply it. Since the “transformation=” and “transform!” append Sketchup’s “Edit…Undo” menu option, recommended practice is to wrap them with start and commit operations:
Sketchup.active_model.start_operation("Barry's Scaling")
. . . code that affects undo operations
Sketchup.active_model.commit_operation
That would set the menu undo option to “Undo Barry’s Scaling”. Additional recommended practice is to include exception handling that calls “.abort_operation” if an error is raised.
The few statements of code do the Pythagoras and trig for you without any trig, as it just involves matrix multiplication.
