I first draw two round faces and then I want to delete them all at once. I know I can delete it similar to this, but I don’t know how many circles there will be? Should I be able to create an array to store this data? Or use some other method?
For example, I first draw a circular surface
Then I delete this data
Only the most recent ones can be deleted, and the data of the first circle drawing is not saved
Please edit your posts and post code snippets, not images.
(From time to time the Amazon servers lose forum images.)
See: [How to] Post correctly formatted and colorized code on the forum?
Because you are reusing the same references and you are setting b
back to an empty array before creating the 2nd face.
Yes you can store object references in an array. But you should do this within the module of your extension, inside your namespace module.
Also, even though Entities#add_circle
returns an array of edges, you can get a single reference to the circle’s ArcCurve
object.
# within your class or extension submodule
@circles = []
circle_edges_1 = aface( 50, [0,0,1] )
@circles << circle_edges_1.first.curve
circle_edges_2 = aface( 50, [0,0,10] )
@circles << circle_edges_2.first.curve
The call to first
on the edges array returns the 1st edge in the array, …
then the call to curve
on the edge, returns it’s Curve
object, or ArcCurve
if it’s a uniform curve with a single center and radius. (In the case of a circular curve, it will be closed, indicated by the start and end angles.)
def aface(rids,pts)
mod = Sketchup.active_model # Open model
ent = mod.entities # All entities in model
sel = mod.selection # Current selection
circle = ent.add_circle pts,[0,0,1],rids
circle_face = ent.add_face circle
return circle
end
rids = 10
pts = [10,0,0]
a = []
b = aface(rids,pts)
a = a+b
If I change a random input, for example pts = [0,10,0], and store it; I get two round faces.
def aface(rids,pts)
return circle
end
rids = 10
pts = [0,10,0]
#a = []
#b = aface(rids,pts)
#a = a+b
ent.erase_entities(a)
When I try to delete this array, I can only delete one face.
Thanks,But I just tried your method and the computer crashed…
Thanks, i know my problems!!!
You got a BugSplat? Did you submit it? And what version did you use?
Care to share it with the rest of us? Would help other that might have similar issue.
I’m using the 2018 version and I found out it was a problem with my stored data.
