how to align with with rotate tool in a kind of diagonal angle? like in the video I want to align that object with the line that is not horizontal or vertical
my suggestion would be to use the MoveAlignMe extension from Fredo6 (on Sketchucation). It has 2 main functions, but from what you describe, use the Move and Glue feature. This will allow you to pick the base point of what you want to rotate, and then pick a point or a face of where you want to align the object to.
when you use the rotate tool, the very first point you pick is the āhingeā if you want.
in your video, you placed it in two different locations, non were right.
the rotation point or hinge remains immobile. since youāve made a guide line to see the angle you need to reach, and since the guideline touches a specific point or your wall, then⦠thatās the point you need to click on.
second point is like the ādoor handleā. thatās where you grab your object, the initial position. and the third click is where you want that handle to arrive.
see this simplified version of your situation
if I pick any other point than the top left, I canāt be precise.
if I rotate around the top left point, then click along the left side, then on the guideline, I have a perfectly aligned rectangle.
The first two clicks are important, choose a dedicated point to start the rotation after picking the ācenter of rotationā.
Once it is in that state, you can hover over edges (no guidelines!) anywhere in the model to pick up itās angle or direction. If the āOn Edgeā tooltip shows up, it is āloadedā in the reference engine. Press Down arrow key to lock parallel or perpendicular to that edge:
