I have a face (my_face) with one outer loop and some inner loops. I wish to use my_face.loops as path for followme. Can you help me for it? Thank you in advance.
DOES NOT TESTED!!!
# Get all points of loops in a face
# Parameters:
# face: <Sketchup::Face>
# tr: (Geom::Transformation) - optional
# - combined transformation for the group(s) / comp.instance(s)
# containing the face
# Return nested Arrays with loop's points or empty Array
# Outer loop points Inner loop pts (if exist) Other Iloop..
# [ [Point3d, Point3d,...], [Point3d, Point3d, ...], .............]
def get_path_by_face_loops(face, tr = IDENTITY)
return [] unless ( face.is_a?(Sketchup::Face) && face.valid? )
outer_loop_pts = []
all_loops_nested_ary = []
face.loops.each{|loop|
if loop.outer?
outer_loop_pts = loop.vertices.map{|v| v.position.transform(tr)}
else
inner_loop_pts = loop.vertices.map{|v| v.position.transform(tr)}
all_loops_nested_ary<<inner_loop_pts
end
all_loops_nested_ary.unshift( outer_loop_pts )
end
then you can call this from your other method like
model = Sketchup.active_model
ents = model.active_entities
path_nested_ary = get_path_by_face_loops(my_face)
#or
# path_nested_ary = get_path_by_face_loops(my_face, my_face_transformation)
if path_nested_ary[0]
outer_path = ents.add_edges path_nested_ary[0]
# or if you want soft path
# outer_path = ents.add_curve path_nested_ary[0]
# assuming the @face1, @face2 are there in other method
@face1.followme outer_path
inner_path1 = ents.add_edges path_nested_ary[1] if path_nested_ary[1]
@face2.followme inner_path1
# ...and so on
end
Dear Dezmo,
I need time to check your codes step by step. I wrote following code for a face.
tr = grp.transformation
if loop.outer?
@i_loop = loop.vertices.map{|v| v.position.transform(tr)}
end
i_grp = Sketchup.active_model.active_entities.add_group
path = i_grp.entities.add_curve @i_loop
you can see result in following photo. One line is missed. Can you tell me why it happen and how can I solve problem?
I see. You have to connect the first point to last in a @i_loop
array , therefore you have to add it’s first element to the end:
path = i_grp.entities.add_curve( @i_loop<<@i_loop.first )
(I missed that in my previous post )
Recommended reading:
