How do you soften a circle ?
I tried to build a similar plug-in. mine combines the soft and smooth steps to a toolbar with on and off functions. From leftr to right is Weld, explode, Soften, unSoften, Smooth, unSmooth
require 'sketchup.rb'
# require 'extensions.rb'
module MP_Extensions
  module MP_Edge_Weld_Tool
    def self.weld_selected_edges
      model = Sketchup.active_model
      selection = model.selection
      edges = selection.grep(Sketchup::Edge)
      if edges.empty?
        show_notification("Please select edges to weld.")
        return
      end
      model.start_operation('MP Weld Edges', true)
      # Use built-in Weld method
      model.active_entities.weld(edges)
      model.commit_operation
      show_notification("Edges welded.")
    end
    def self.explode_curve
      entities = model.active_entities
      vertices = selection.grep(Sketchup::Face).map(&:vertices).flatten.uniq
  	if vertices.empty?
        show_notification("Please select faces to explode the edges.")
        return
      end
      model.start_operation('MP Explode Curve', true)
      # Explode curves if any
      vertices.each do |vertex|
        vertex.edges[0].explode_curve
      end
      show_notification("Edges exploded.")
    end
    def self.soften_curve
       # Iterate through the selected entities
  	if edges.empty?
        show_notification("Please select edges to soften.")
        return
      end
	model.start_operation('MP Soften Curve', true)
	selection.each do |entity|
      # Check if the entity is an edge and soften it
        if entity.is_a?(Sketchup::Edge)
          entity.soft = true
        end
	end
	show_notification("Edges softened.")
    end
    def self.unsoften_curve
  	if edges.empty?
        show_notification("Please select edges to unsoften.")
        return
      end
	model.start_operation('MP Unsoften Curve', true)
          entity.soft = false
        end
	end
	show_notification("Edges unsoftened.")
    end
    def self.smooth_curve
  	if edges.empty?
        show_notification("Please select a face and edges to smooth.")
        return
      end
	model.start_operation('MP Smooth', true)
      # Check if the entity is a face and smooth it
          entity.smooth = true
        end
	end
	show_notification("Smoothing complete.")
    end
    def self.unsmooth_curve
  	if edges.empty?
        show_notification("Please select a face and edges to unsmooth.")
        return
      end
	model.start_operation('MP UnSmooth', true)
      # Check if the entity is a face and unsmooth it
          entity.smooth = false
        end
	end
	show_notification("UnSmoothing complete.")
    end
    def self.show_notification(message)
      dialog = UI::HtmlDialog.new(
        dialog_title: "MP Edge Modifications",
        scrollable: false,
        resizable: false,
        width: 300,
        height: 100,
        style: UI::HtmlDialog::STYLE_DIALOG
      html_content = <<-HTML
        <html>
        <head>
          <style>
            body { font-family: Arial, sans-serif; text-align: center; padding: 15px; }
            .message { font-size: 16px; }
          </style>
        </head>
        <body>
          <div class="message">#{message}</div>
          <script>
            setTimeout(function() {
              window.close();
            }, 1500);
          </script>
        </body>
        </html>
      HTML
      dialog.set_html(html_content)
      dialog.center
      dialog.show
    end
    def self.create_toolbar
      toolbar = UI::Toolbar.new("MP Edge Tools")
      weld_cmd = UI::Command.new("MP Weld Edges") { weld_selected_edges }
      weld_cmd.tooltip = "MP Weld Edges"
      weld_cmd.status_bar_text = "Weld selected edges into a polyline"
      weld_cmd.small_icon = weld_cmd.large_icon = File.join(__dir__, 'img', 'weld.png')
      explode_cmd = UI::Command.new("MP Explode Edges") { explode_curve }
      explode_cmd.tooltip = "MP Explode Edges"
      explode_cmd.status_bar_text = "Explode selected curve into separate edges (Double click face first)"
      explode_cmd.small_icon = explode_cmd.large_icon = File.join(__dir__, 'img', 'explode.png')
	    soft_cmd = UI::Command.new("MP Soften Edges") { soften_curve }
      soft_cmd.tooltip = "MP Soften Edges"
      soft_cmd.status_bar_text = "Soften only selected edges"
      soft_cmd.small_icon = soft_cmd.large_icon = File.join(__dir__, 'img', 'soft.png')
	    unsoft_cmd = UI::Command.new("MP Unsoften Edges") { unsoften_curve }
      unsoft_cmd.tooltip = "MP Unsoften Edges"
      unsoft_cmd.status_bar_text = "Unsoften only selected edges"
      unsoft_cmd.small_icon = unsoft_cmd.large_icon = File.join(__dir__, 'img', 'unsoft.png')
	    smooth_cmd = UI::Command.new("MP Smooth") { smooth_curve }
      smooth_cmd.tooltip = "MP Smooth"
      smooth_cmd.status_bar_text = "Smooth selected face shading"
      smooth_cmd.small_icon = smooth_cmd.large_icon = File.join(__dir__, 'img', 'smooth.png')
	    unsmooth_cmd = UI::Command.new("MP UnSmooth") { unsmooth_curve }
      unsmooth_cmd.tooltip = "MP UnSmooth"
      unsmooth_cmd.status_bar_text = "UnSmooth selected face shading"
      unsmooth_cmd.small_icon = unsmooth_cmd.large_icon = File.join(__dir__, 'img', 'unsmooth.png')
      toolbar.add_item(weld_cmd)
      toolbar.add_item(explode_cmd)
	    toolbar.add_item(soft_cmd)
	    toolbar.add_item(unsoft_cmd)
	    toolbar.add_item(smooth_cmd)
	    toolbar.add_item(unsmooth_cmd)
      toolbar.show
    end
    # Create the toolbar when the script loads
    MP_Edge_Weld_Tool.create_toolbar
  end # module MP_Weld_Tool
end # module MP_Extensions
That’s perfect !
When posting here, I didn’t expect to come home with a tailored extension.
It has now its own shortcut “Shift+Alt+M”, and should stay there for a while.
Thank you again!
It’s a good idea to bring all these settings in the shape of icons. Specially for people who like toolbars. I’d say the first 2 icons got me confused though, as I thought they were controlling Hide/Unhide. This dotted line didn’t quite evoked “exploded” to me, as sketchup is rather using dotted lines do display non visible stuff. But that’s maybe just me.
Did the icons were also designed by AI ?
No. That was me. I had a hard time coming up with a visual to show welded (solid) or broken (exploded) I suppose I could have used blue line and add red dots for nodes on the exploded version. But hovering does show tool tips on the function. I agree they were not the best icon choice
