How can I use SUEntitiesTransform function?
Hi, is there any example of SUEntitiesTransform function?
Did you check the examples that came with the SDK package ?
Also the Ruby API doc examples may help a bit:
Also, the Ruby API equivalent method for that C function is:
This example works for me - it’s a slightly modified code copied from the Quick Start examples.
I find it interesting that the function takes an array of SUEntityRef objects. I would have expected it to take only SUDrawingElementRef objects.
I’m glad I discovered this, though, it means that entities can be manipulated in the C API.
I suppose this to allow things like a Vertex which is not a DrawingElement but is transformable.
