spawn
August 25, 2017, 4:03pm
1
Hi everybody.
I know TIG developed an extension called True Tangents, but I wasn’t able to get this.
The center has to be situated in line called B.
The circle has to touch A,C and D.
It would be something like this:
question.skp (17.2 KB)
I almost forget to thank in advance
TIG
August 25, 2017, 5:59pm
2
With my TrueTangents toolset you can get a cpoint at the intersection of arcs A and C, and much more…
This intersection-point will NOT necessarily fall on line B.
You can determine the intersection of A & C, or A & B, or C & B.
BUT not all three at once unless they are coincidental by accident !
So find the intersection of something important to you [like A & C] and the create the line through that, which approximates to B…
By my calculation, the radius of the circle through D and tangent to A and C should be 3.1066".
The intersection of A and C is 3.1292" from D.
I agree with @sdmitch . The formula I came up with is
r = (D^2+H^2-R^2)/(2(H-R))
Where
D is the distance from line B to the arc centers
H is the distance from the line of arc centers to point B
R is the radius of the arcs
Edit: whoops you labeled the point I called B as D! I should have used some other symbol for what I called D! Otherwise the formula is correct.
spawn
August 25, 2017, 8:26pm
5
Thank you guys for your answers and the formula, it will be useful but it looks hard I mean it requires to use the calculator (at least for me)
Isn’t there any calculator built-in on sketchup, right?
I will make some tests with the formula.
TIG, about the extension … I still don’t get how to use it to get the point, I mean … am I using it on the right way?
spawn
August 25, 2017, 8:37pm
6
slbaumgartner
Do I have to change D by B in your formula? or it’s corrected after your editing?
No need to modify the formula if you read it right:
D is the distance from the arc centers to line B
H is the distance from the line of centers to the point you labeled “D”
system
Closed
November 25, 2017, 2:05pm
9
