How can get UV when material on group?
How can get UV when material on group?.
You probably cannot.
Materials must be put on the faces of you want to get a UV map.
@francisquitof is most likely correct
Here’s a bit of test code that reports UVs for the first face in the first container in the model.
model = Sketchup.active_model
ents = model.active_entities
grp = ents[0]  # assume the first item is a group or component
mat = grp.material
face = grp.definition.entities.grep(Sketchup::Face)[0]
unless face.material = nil
  face.material = mat
  tw = Sketchup.create_texture_writer
  uv_helper = face.get_UVHelper(true, true, tw)
  face.outer_loop.vertices.each do |vert|
    uvq = uv_helper.get_front_UVQ(vert.position)
    # "Normalize" UVQ to UV.
    # #x, #y and #z corresponds to U, V and Q respectively,
    # as SketchUp re-uses the normal Point3d objects for UVQs
    u = uvq.x / uvq.z
    v = uvq.y / uvq.z
    puts "u=#{u} v=#{v}"
  end
  #face.material = nil
  Sketchup.undo
end # if
This is the way I use now, but I think the efficiency is too low.
I started working out the mathematics producing the projection of the image onto the surface with this model.
1234567890.skp (113.7 KB)
Now I’m waiting for the penny to drop.
I solved the calculation under orthographic projection.
def calculate_face_uv_tr(face, mat)
  return IDENTITY unless mat
  return IDENTITY unless mat.texture
  tr = Geom::Transformation.new(ORIGIN, face.normal)
  width, height = mat.texture.width, mat.texture.height
  uv_tr = Geom::Transformation.scaling(ORIGIN, 1 / width, 1 / height, 0)
  uv_tr * tr.inverse
end
Well done.
Here’s the way I’m visualizing the question.
Also, there are often two special cases to investigate. What happens when the face normal is a straight up or straight down.
I used a fourteen sided body test and found no problems.
The tetrahedron is formed by cutting off eight corners from a cube.
Three.js
SketchUp
