Hi all.
Sorry for my noobness here but I am just tinkering around with a camper trailer design I want to build and to make it more interactive I want to animate the fixed awning side.
I want part A and part B to slide out of the camper together and then part B rotate upward.
I can get part A to slide.
I can get part B to rotate.
But I can’t get the two parts to stay together. Part B wont stick with part A
Anyone able to … in a really basic way… help me get this please?
I have tried to follow tutorials on sliding doors and cupboards etc.
What are you using to do the animation? Are you trying to make a dynamic component? Or are you just wanting to animate using tags and scenes? Or are you using an animator extension?
It looks like your model needs some help before you get to the point of animating it. It is hard to tell from just a screen shot exactly what you’ve got going on with your parts A and B.
What version of SketchUp are you really using? Your profile says you are using SketchUp Pro 3.04 which was never available as a subscription and would be from 18 years ago.
wow…pow pow pow…
I was in fact using a very old sketchup from prob not quite 18 years ago…long before subscription existed… or Trimble. I only tinker with it here n there.
I today installed “Make” to be more up to date.
I imagine there are many issues. I only use this on the odd occasion. last was aroung 2015.
I am just using dynamic components.
Hopefully there’s some help on the other side of this!?
OK. That helps. If you want the components to move together, select them and put them in a larger component. Then you can move the whole thing as a single unit or you can move one without moving the other if you want to create a telescoping sort of effect.
It would be easier to give you guidance if you upload the model file.
Be aware that SketchUp Make starts with a 30-day Pro trial. After that it reverts to Make. Creating and editing Dynamic Components is a pro-only feature.
Since your question refers to using Dynamic Components, I moved it to the Dynamic Component forum category.
HI john_mcclenahan
My trial has ended.
Any possibility you could screen shot the dynamic component window and I can transfer the parameters into my old sketchup please?
