Nozzle.skp (431.2 KB)
I am trying to model a crevice tool for my Rigid Vacuum. In the attached file is a picture from Home Depot’s website of what I am aiming for. Also in the file are the two objects I am trying to combine. I am totally clueless how to do this, I tried a bunch of different things, but none came close to what I wanted. As always, any help from the SU community will be greatly appreciated.
I would suggest that you:
1 - Reorient your model so gthat the blue axis points up instead of down.
2 - Use Perspective Camera instead of Parallel Projection.
3 - Realign the two parts with the axes. Actually they are all skewed about all the axis and are not aligned correctly together.
See this SU file.
Nozzle - JL - 2024-09-05.skp (613.0 KB)
Even with these corrections, I am not convinced that you can get a precise model. I suggest that you start from scratch.
Click in sequence on the scenes tabs of this SU file for ideas.
Nozzle ideas - JL - 2024-09-05.skp (155.8 KB)
Jean - thanks for the suggestions and taking the time to provide the step by step instructions. This will work just fine.
