GORebar - SketchUp plugin for placing reinforcing steel for beams and columns
Hello, I would like to request your help in testing a plugin for creating reinforcing steel beams and columns.
:tada: GoRebar v1.2.0 - SketchUp plugin for placing reinforcing steel for beams and columns :building_construction:
:high_voltage: Main features:
:white_check_mark: Placing beams - Supporting single-span beams Includes extra reinforcing bars (Extra Bars)
:white_check_mark: Column placement - both square and round, supporting zone spacing
:white_check_mark: Create complete and ready-to-use formwork (tube and wooden forms)
:white_check_mark: Automatic formwork calculation - calculating the quantity of steel, concrete, and formwork
:white_check_mark: Export as CSV - directly to Excel
:wrench: Key Features:
:triangular_ruler: Supports all steel sizes:
• Main steel: DB10, DB12, DB16, DB20, DB25, DB28, DB32
• Stirrup steel: RB6, DB8, RB9, DB10, DB12
:artist_palette: Each steel size has a different color - easy to see and clearly distinguish
:bar_chart: Complete Quantity Report:
• Length of each steel type (including hook)
• Total weight (kg)
• Concrete volume (m³)
• Tube area (m²)
:gear: Fully customizable:
• Hook 90°
• Left-Right Extension
• Uniform or Zone (L/4) Stirrup
• Top-Bottom Extra Bars (Supports + Mid-Span)
:bullseye: Realistic Formwork:
• Beams: 3 sides (bottom + 2 sides)
• Square Columns: 4 sides
• Round Columns: Smooth cylindrical shape
:light_bulb: Easy to Use in 3 Steps:
:one: Select the beam or column Group/Component
:two: Fill in the information on the UI (steel dimensions, spacing, etc.)
:three: Press Generate - Done instantly! :rocket:
:package: Download: https://www.youtube.com/watch?v=hH95Cvi8Jww&t=1189s
:money_bag: Price: Free! :man_technologist: Developed by: PHORNJED P.
