I tried all the methode but nothing work !
the probleme is when i try to do nesting with abf he doesnt nesting this like1 parte he nest it like seperate partes
GOLA L.skp (114.3 KB) LOOK FOR THE SIDE TRY TO USE NESTING WITH ABF OR OPENCUTLIST HE WILL READ IT LIKE 1 PARTE BUT WHEN I TRY THIS METHODE IT WILL READ IT 3
PARTES
If you make 3 solid groups and then make them into 1 component that gets read by OCL as a single part.
I use ABF plugin so that methode doesnt work with me !
You mentioned open cut list.
Basically you need to experiment and try and understand what logic is being used by a specific plugin if that’s the one you want to use!!!q1111
Yeah i understand you but . I use ABF for drilling and fitting and create a dxf file directly to cnc . i have a model of this cabinet i can send it to u to try to figure out how he done it if u want
Just explode the three objects and make it one single object.
I did like u said but when i try to nest it with ABF plugin it nesting 3 parts not 1
Then evidently you didn’t explode the three objects inside the top level one.
Abf works with groupes not component but one of the designer create it lile the way i share it the GIF up a component and work it with ABF normaly so i didnt figure the solution how he did it that why i think maybe the method of divide he use it ..
