Global Attribute value overiding Component Attribute forumula
Hi, Can anyone advise:
I have made a cabinet which is a Dynamic Component for which I want the option of adjusting the Plinth Height in 2 ways:
  1. Changing the attribute value for the component itself (using Component Attributes field)
  2. Using a ‘global’ value based on a separate component within the model (a swatch which has the purpose of custom global attributes which the other components refer to).
I have linked the ‘Plinth Height’ value to the Global value which works fine (using a re-draw tool to implement the change), however when I use the component’s own attribute option to change the value, it overides and deletes the formula for the Global value. So it also works but means I can no longer use the Global attribute to change it.
Does anyone know a way around this?
So I am thinking that maybe an IF statment could solve the problem, so In theory the following should work:
IF (Component!PlinthHeight>0,Component!PlinthHeight,Global!PlinthHeight)
use a dropdown with formula in the values for ‘Plinth Height’
Gobal … = gobal!pinth
Custom … = custom
100mm … =10
120mm … =12
150mm … =15
where custom is a fillable textbox
Thanks for that. I didn’t quite understand what to put where, although actually I don’t like the idea of having a drop down as the height can be quite specific (by millimeter)…
the custom would allow any other value unique to each DC
separate hidden plinth height attribute
Plinth… = if(plinth_height,plinth_height, global!plinth)
so if the plinth_height text box <=0. then it will be the global
There is a third way, using on click to get the options
for scale and global, textbox is hidden, using a set(), however as there are two “NONE”, used choose on additional attribute
example of the three methods
overwrote the first, so here is the amended file
global options.skp (77.6 KB)
Thank you for the info, its really helpful, the code for the plinth attributes especially, I’ll give it a try…
