# module wrapper
module JcB
extend self
# simple cypher
ALPHABET = 'abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789'.freeze
# generated with .split('').shuffle.join
ENCODING = 'MOhqm0PnycUZeLdK8YvDCgNfb7FJtiHT52BrxoAkas9RWlXpEujSGI64VzQ31w'.freeze
def encode(strng)
if strng.class == String
return strng.tr(ALPHABET, ENCODING)
else
return strng
end
end
def decode(strng)
return strng.tr(ENCODING, ALPHABET)
else
return strng
end
end
def break_dc
m = Sketchup.active_model
m.definitions.each do |d|
next unless d.attribute_dictionaries && d.attribute_dictionaries['dynamic_attributes']
d.get_attributes('dynamic_attributes').each do |a|
d.set_attribute('encrypt_attributes', encode(a[0]), encode(a[1]))
d.attribute_dictionaries.delete('dynamic_attributes')
end
d.instances.each do |i|
next unless i.attribute_dictionaries && i.attribute_dictionaries['dynamic_attributes']
i.get_attributes('dynamic_attributes').each do |a|
i.set_attribute('encrypt_attributes', encode(a[0]), encode(a[1]))
i.attribute_dictionaries.delete('dynamic_attributes')
end end end
m.definitions.purge_unused
next unless d.attribute_dictionaries && d.attribute_dictionaries['encrypt_attributes']
p d
d.get_attributes('encrypt_attributes').each do |a|
p a
end end
end
def fix_dc
d.set_attribute('dynamic_attributes', decode(a[0]), decode(a[1]))
d.attribute_dictionaries.delete('encrypt_attributes')
end
next unless i.attribute_dictionaries && i.attribute_dictionaries['encrypt_attributes']
i.get_attributes('encrypt_attributes').each do |a|
i.set_attribute('dynamic_attributes', decode(a[0]), decode(a[1]))
i.attribute_dictionaries.delete('encrypt_attributes')
end end end
p d
p a
end end
end
end
i am getting the following error.
Error: #<NoMethodError: undefined method get_attributes' for #<Sketchup::ComponentDefinition:0x000001fdfe4e29d0> Did you mean? get_attribute set_attribute> C:/Users/it/Desktop/encrypt/encrypt_dc.rb:30:in block in break_dc’
C:/Users/it/Desktop/encrypt/encrypt_dc.rb:28:in each' C:/Users/it/Desktop/encrypt/encrypt_dc.rb:28:in break_dc’
I don’t think using ENCODING is wise as Ruby has a class of this name, ie: Encoding which is used for character encoding for files and strings.
I would suggest using the constant identifier CYPHER or CRYPTOGRAPH instead.
It is very clear by the error message: "NoMethodError: undefined method 'get_attributes' for #<Sketchup::ComponentDefinition:...>"
So the Sketchup::ComponentDefinition class does not have a method named "get_attributes".
Your indentation is atrocious ! If you want help with your code, … ident correctly.
Don’t do … end end end This is crazy coding!
To iterate an attribute dictionary:
dict = obj.attribute_dictionary('dictionary_name')
next unless dict # nil if does not exist
dict.each do |key, val|
# ... code using key and/or value
end
Dictionaries are hash-like objects consisting of key + value pairs. Trying to access via a[0] and a[1] is weird. Use the key and val block parameter pattern instead. (Ie, you doing things the hard way.)
The SketchUp Ruby API has no method called get_attributes. It looks as it has been incorrectly defined in the shared namespace by one of the old shipped extensions.
You can instead try attribute_dictionary (API docs) to get one specific directory and then iterate over its content.
Basically i am looking how to protect the dc attributes, formulas in the dynamic components to protect from modification by others without compromising the functionality of the DC’s.
If you encrypt the attributes and delete the DC dictionaries then they become unusable “dumb” components that cannot be used with the Dynamic Components extension.
In order for them to be dynamic then your code would need to restore the DC dictionaries, at which time all a user needs to do is select and right-click a dynamic component and save it out to a file into order to circumvent your “protection”.
Ie, the API does not have an observer callback that fires when a definition (or copy) is saved out to storage, so you cannot prevent this.
