sigh
sigh sigh
another Saturday morning on the forum.
sigh
sigh sigh
hola. podrias ayudarme a recuperarlo? porfa
You changed the SketchUp version from Free Plan to SketchUp for Schools. Thatâs a web based version for young school children. Are you a child? Or are you using a cracked version of SketchUp? The real version you are using will have an impact on whether we can recover it or not.
What operating system? 2023 is not an operating system. What graphics card model? âgraphics cardâ is not the answer.
You still havenât made the file available on Google Drive so we have no way to help you.
Me temo que poca ayuda vas a recibir en este foro con software ilegalâŚ
Estas intentando utilizar la versiĂłn de escritorio y tu perfil dice que tienes âFree Planâ no estĂĄ incluido en tu plan.
You are trying to use the desktop version and your profile says that you have âFree Planâ itâs not included in your plan
You would need to share the .skp file so we can try to help you. Also share the .skb backup file. Your profile says you are using âFree Planâ 2024. Does that mean you are using a cracked version?
Me sale un error de formato de archivo inesperado y no puedo abrir ni el archivo original ni el recuperado.
ARCHIVO: https://we.tl/t-er2hHoHhHj
@colin HELP ME!
Your profile shows you are using Free Plan 2023. Does that mean you are using a cracked version of SketchUp?
There is a bad group in your model. If you update to the latest version of SketchUp 2023 or to SketchUp 2024 youâll be able to open the file. It opened fine after dealing with the bad group. You should fix incorrect tag usage and purge unused stuff. I did that which reduced the file size by 70%
Can you send me the file please?
Why donât you just update to the latest version of SketchUp 2023 or update to SketchUp 2024? Then you can open your file.
About 2/3 of the file is empty. I am afraid that you have to start again. Or can you try opening the backup (skb) file by renaming its extension to SKP?
@Anssi has already told you whatâs wrong with your SketchUp file so I wonât look at it. Did you have any luck with the .skb file?
Your profile says you are using âFree Planâ 2023. Does that mean you are using a cracked version of SketchUp? Where are you saving the SketchUp file while you are working on it? The answers to these questions are important in helping you get this sorted out.
DAMAGED FILE, I NEED TO RECOVER IT, I DONâT HAVE THE STB.
It seems to be missing important chunks of data.
Presumably you mean .skb file. Why donât you have the backup file?
Where have you been saving the file while working on it?
What version of SketchUp are you really using? There is no Free Plan 2024 as you put in your forum profile. What operating system? What graphics card? âGRACIASâ is neither an operating system nor a graphics card.
Buenas noches, podrĂas ayudar a recuperar este archivo de Sketchup? al intentar abrirlo me aparece error al abrir este documento. Por Favor
I couldnât get anything from the SKP, and only some materials from the SKB. Couldnât recover any of the model.
Me temo que sĂ. ÂżQue versiĂłn tienes?, no existe una versiĂłn gratuita de SketchUp Pro 2023.
Do you have a cracked version of SketchUp 2023?
Hello @colin can you help me plese to try to repair my file⌠pleaseâŚ
This is my file:
