Hello, I’ve just finished to transfer a blue print on sketchup. It is a raw desiggn but good enough to start from.
Problem is that now many spaces with four sides which are apparenlty completely connected and are on the same plane, are not colour filled with and then they are not clickable then I cannot push the for walls out in order to create the 3d model
Thanks in advance
Max
https://app.sketchup.com/share/tc/northAmerica/28W18eb1H1s?stoken=H9EGyJAZXymGCHBHmczpQQ8bnbKUtPgAhmNg6c3zMyu0NECXiCBVPQwshjr0TATT&source=web
A commonly used approach to help assure that lines are all co-planar when tracing or otherwise constructing an outline in pieces is to create a large rectangle or polygon at the desired location and orientation, then create the edges on that face (easy to do thanks to SketchUp’s inferencing system), then delete the unwanted outer portion of the face. (I prefer using a polygon as the initial face because selecting the outer perimeter for subsequent deletion is easily done with one click.)
You can use a plugin like vertex tools to flatten all the geometry, or create a plane and with a plugin like push line extrude everything on the Zaxis, then intersect the lines with the plane and you’ll have all the geometry flat and with faces created.
Not in the Web version unfortunately.
At work now but I can take a look at your model later if others don’t beat me to it.
