Filling holes between faces after drawing 2 faces
hello everyone,
i’m creating a sketchup ruby plugin to draw faces using height,width and length, but as you can see in the picture bellow when i draw the 2 faces A in the blue model manually automatically the hole between the two is closed but when i add 2 faces B in the green model using the add_face function it doesn’t close it, but i draw the yellow line manually in the green model the hole closes.
can any one help how can i close that hole by ruby code ? like when i draw the faces manually ?
thnx a lot in advance.
I will assume you have a reference to the “yellow” edge:
yellow_edge.find_faces()
See: Sketchup::Edge#find_faces()
no the yellow edge i’ve just draw it in the picture to explain more my problem
It doesn’t matter. What I said is the solution.
So you will need to get a reference to one of the hole’s edges (it doesn’t matter which,) so that you can call find_faces() upon it.
It will not hurt to call find_faces() upon all edges of any new face you create:
  face = entities.add_face( pts )
  face.edges.each {|edge| edge.find_faces }
awesome thank you so much for your help
i tried your method but it doesn’t seem to work the hole is still there, even if i called find_faces on all edges of the new faces in the picture above referred to as B.
How about posting a test model and a code snippet ?
oky that’s a code snippet and the model :
  model = Sketchup.active_model
  entities = model.entities
    w=2*39.37
    h1=2*39.37
    h2=1*39.37
    pts=[]
      pts[0] = [100, 0, h1]
      pts[1] = [w+100, 0, h1]
      pts[2] = [w+100, w, h1]
      pts[3] = [100, w, h1]
   face = entities.add_face pts
   face.edges.each {|edge| edge.find_faces}
          pts[0] = [100, w, h2]
          pts[1] = [w+100, w, h2]
          pts[2] = [w+100, 2*w, h2]
          pts[3] = [100, 2*w, h2]
faces_holes.skp (104.5 KB)
You have faces reversed (inside-facing-out.)
And I think that the order of points may be passed to add_face() may be reversed.
When I reverse the faces manually, then select evrything and run:
ss = Sketchup.active_model.selection
ss.grep(Sketchup::Edge) {|e| e.find_faces }
… the face on the bottom is made, but not the hole between your new faces.
yeah same only the bottom is created why is that ? i changed the order of points given to add_face but it still not reversed ? how can i reverse all face ?
your supplied model isn’t accurate enough…
change to mm and 6 decimals and check the side heights…
john
it worked thank you so much for your help everyone, there a little space between the roof and faces.
part of the problem is your defining the conversion to model units…
2*39.37 == 2.m.to_inch
=> false
2.m.to_inch == 78.74015748031496
john
So the hole’s edges were not co-planar ?
yes there was a small space between the roof named A and the vertices of the walls underneath it
