See test ruby snippet below which transforms a face (which is positioned at an arbitrary angle in 3D space) so that it is flat on the XY plane at the origin. Everything works as expected except that, after the transform, the face is not selectable(??) Red face on right is a copy in the original position, Left is new position. Edges are still selectable. (White platform is a group and shown for spatial clarity) If I double click an edge the face and all 4 edges select, But I can’t select the face itself. What could cause this? If I save file and reload, then face is selectable.
mod = Sketchup.active_model # Open model
ent = mod.entities # All entities in model
sel = mod.selection # Current selection
status = mod.start_operation(“originate”, false)
selface = sel[0]
xyznormal = selface.normal
faceoriginpt = selface.edges[0].start.position
origintrans = self.originate xyznormal, faceoriginpt
ent.transform_entities(origintrans.inverse, selface)
status = mod.commit_operation
originate.skp (1.2 MB) I’ve uploaded model and here is full code. To run, first select the left red face, then execute.
module Bm_test
def self.originate(xyznormal, faceoriginpt)
# rotate face to global XY
#normal is the z axis
#define axes of face
# create xaxis vector
ptx = Geom::Point3d.new(1,0,0)
xaxis = Geom::Vector3d.new(1,0,0)
#create yaxis vector first create 2 points
pt0 = Geom::Point3d.new(0,0,0)
pty = Geom::Point3d.new(1,0,0)
cpty = ent.add_cpoint pty
#rotate pty by 90 degrees around normal at pt0
transz90 = Geom::Transformation.rotation pt0, xyznormal, 90.degrees
ent.transform_entities(transz90, cpty)
pty = cpty.position
# erase const point
ent.erase_entities cpty
yaxis = Geom::Vector3d.new(pty.to_a)
#=begin
#draw to confirm: omit in final version
clinex = ent.add_cline pt0, ptx
cptx = ent.add_cpoint ptx
cliney = ent.add_cline pt0, pty
ptz = Geom::Point3d.new(xyznormal.to_a)
clinez = ent.add_cline pt0, ptz
cptz = ent.add_cpoint ptz
#=end
#use start position of face as rotation point
origintrans = Geom::Transformation.axes faceoriginpt, xaxis, yaxis, xyznormal
return origintrans
end #def
#test: for one selected face
status = mod.start_operation("originate", false)
selface = sel[0]
#ent.transform_entities(origintrans, selface)
end #module
It seems # in first position creates headings(??) so here’s another try:
module Bm_test
pty = cpty.position
# erase const point
#=begin
#=end
return origintrans
end #def
selface = sel[0]
end #module
I see I made a mistake where the 3 axes I passed to Geom::Transformation.axes are not actually perpendicular to each other. Apparently that method doesn’t check for that problem, resulting in a warped face?
