Extrude face without deforming the initial face
Hi, I am new in Ruby. Can someone please explain me how can I extrude a face without any deformation of the initial face. I manage to do this for circle but not for rectangle. Please see:
 model = Sketchup.active_model # Open model
 ents = model.entities # All entities in model
 sel = model.selection # Current selection
@edges = []
       ents.each do |e|
         if e.is_a? Sketchup::Edge
            @edges << e
         end
      end
def gh # -------------------------------------------------------------------------------------------------------- this works
0.upto(@edges.count-1) {|x|
entities = model.entities # All entities in model
new_comp_def_xy = Sketchup.active_model.definitions.add("extrude")
center = Geom::Point3d.new @edges[x].start.position
vector = Geom::Vector3d.new [@edges[x].end.position.x - @edges[x].start.position.x,@edges[x].end.position.y - @edges[x].start.position.y,@edges[x].end.position.z - @edges[x].start.position.z]
tr = Geom::Transformation.new(center)
circle = new_comp_def_xy.entities.add_circle center, vector, 0.025.m
circle_face = new_comp_def_xy.entities.add_face(circle)
circle_face.followme @edges[x]
rest = Sketchup.active_model.active_entities.add_instance(new_comp_def_xy, tr )
end
def asd # ------------------------------------------------------------------------------------------------ not working properly
gp = entities.add_group()
                  points = Array.new
                  points[0] = [0.03.m, 0.03.m, 0.m]
                  points[1] = [0.03.m, -0.03.m, 0]
                  points[2] = [-0.03.m, -0.03.m, 0]
                  points[3] = [-0.03.m, 0.03.m, 0]
                  points[4] = [0.03.m, 0.03.m, 0.m]
                  newface1 = new_comp_def_xy.entities.add_face(points)
                newface1.reverse!
                status = newface1.pushpull @edges[x].length
                point = Geom::Point3d.new
                as = Geom::Transformation.new(@edges[x].start.position)
Sketchup.active_model.active_entities.add_instance(new_comp_def_xy, as)
                        points.clear
end
thank you in advance
Please edit your post and surround the code with lines like these (triple backtick at the left margin):
 ```ruby
 # your code here
That will make it much easier for all of us to read!  Thanks.
Thank you slbaumgartner
You need to treat the rectangle the same as the circle by defining the transformation as the center,vector
@edges = sel.grep(Sketchup::Edge)
  center,vector = @edges[x].line
  gp = ents.add_group()
  points = Array.new
  newface1.reverse!
  as = Geom::Transformation.new(center,vector)
  points.clear
Perfect, Thank you so much sdmitch.
