Exporting standard views into JPG-Files with extension or suby script
Hi
I want to export the six standard views into jpgs-files.
This views are the wellknown ISO, FRONT, BEHIND, TOP, RIGHT, LEFT
Before saving each view it should make a SHOW ALL command so that the complete model is visible.
The directory where to save the jpgs should be the same as SKP-directory.
How can I achieve a one-click solution?
Not exactly one click but you can create scenes with “default” views with this:
http://sketchucation.com/forums/viewtopic.php?p=269442#p269442
then you can export with this:
Note: Both plugins ( script ) are “old style” rb files, (default_scenes.rb, sceneExporter.rb) and need to be manually copied to your plugin folder (Something like this):
c:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2019\SketchUp\Plugins
Very good, that works for me.
I added some ruby-code from SCeneExproter into the default scene and I am fine!
Thank you very much.
