Continuing the discussion from Ruby API model.importToPoint:
NOTE: This is a hacky workaround for old versions. With the 2021.1 release we now have a Sketchup::DefinitionList#import method that can import non-SKP files directly as a component definition. A subsequent code statement can then place an instance of the imported component at a given point.
For the 2021.1 and newer recommended coding pattern, see:
How to import SKP to a 3dpoint? Why is it stuck on my mouse? - #8 by DanRathbun
Here is my example for versions older than 2021.1. It should now be cross-platform. I found a reference to a cancel action string at the Apple Developer website.
Here is v 2.0.0:
import_3ds_to_point_cross_platfrom.rb (2.5 KB)
NOTE: The imported definition will have triangulated faces.(You’ll need to deal with that issue separately.)
# encoding: UTF-8
# Example of importing a 3ds file to a specific transformation.
# by Dan Rathbun, v 2.0.0, made cross-platform
module Author
module SomePlugin
extend self
WIN = Sketchup::platform == :platform_win rescue RUBY_PLATFORM !~ /darwin/i
if WIN
require "win32ole"
end
@@loaded = false unless defined?(@@loaded)
def send_escape()
if WIN
WIN32OLE::new('WScript.Shell').SendKeys('{ESC}')
else
Sketchup::send_action('cancelOperation:')
end
end
# Import a 3ds file to a given transform, point, etc.
# The 1st (xform) argument is required, and can an Array,
# point, vector or transformation object.
# If a path string is not supplied (2nd argument,)
# a file open dialog will prompt for the file to import.
# Returns nil if user cancels file open dialog.
# Returns the added component instance if successful.
def import_3ds_to_point(
xform, # an Array, point, vector or transformation object
path = UI.openpanel("Choose 3ds file to import...","*.3ds")
return nil if path.nil?
unless path.is_a?(String)
fail(
TypeError,
"String pathname to importable model file expected.",
caller
else
unless File.exist?(path)
fail(
ArgumentError,
"Invalid pathname to importable model file.",
caller
end
end
if xform.is_a?(Geom::Point3d) || xform.is_a?(Geom::Vector3d) || xform.is_a?(Array)
transform = Geom::Transformation::new( xform )
elsif !xform.is_a?(Geom::Transformation)
fail(
TypeError,
"Geom::Transformation, Geom::Point3d, Geom::Vector3d, or Array expected.",
caller
else
transform = xform
end
mdl = Sketchup.active_model
result = mdl.import(path)
if result # returned as soon as definition is loaded
send_escape() # to cancel placing with the mouse
cdef = mdl.definitions[-1]
cinst = mdl.active_entities.add_instance(
cdef,
transform
end
end ###
if !@@loaded
UI.add_context_menu_handler {|popup|
popup.add_item("Test 3ds Import") do
import_3ds_to_point([30,30,30])
end
end
end # specific plugin namspace
end # toplevel namespace
It has been pointed out that reliance upon [-1] on API collections is not a contract to always return the most recently added member of a collection.
So we can substitute an array snapshot subtraction pattern …
In the example above, in the import_3ds_to_point() method, the following code snippet …
cdef,
transform
end
… would change to …
before = mdl.definitions.to_a # array snapshot of definitions collection
added = mdl.definitions.to_a - before
cdef = added.first
cdef,
transform
end
