El archivo no parece ser un modelo de sketchup
Hola comunidad,
Necesito ayuda con un problema que estoy enfrentando al intentar abrir un archivo en SketchUp. Cada vez que intento abrirlo, recibo un mensaje de error que dice “El archivo no parece ser un modelo de SketchUp”. Este archivo es crucial para mi proyecto actual y su inaccesibilidad está causando retrasos significativos. He intentado abrirlo en varias ocasiones sin éxito y estoy buscando asistencia técnica para resolver este problema lo antes posible. Si alguien tiene alguna sugerencia o solución, ¡se lo agradecería mucho
¡Gracias de antemano por cualquier ayuda que puedan brindarme!
Hello community,
I need help with an issue I’m facing when trying to open a file in SketchUp. Every time I attempt to open it, I receive an error message stating “The file does not appear to be a SketchUp model.” This file is crucial for my current project, and its inaccessibility is causing significant delays. I’ve tried opening it several times without success and am seeking technical assistance to resolve this issue as soon as possible. If anyone has any suggestions or solutions, I would greatly appreciate it!
Thank you in advance for any help you can provide!
https://drive.google.com/drive/folders/197MZxaiXH12jomsl2zgy0TNHTWZZm1HX?usp=sharing
your files are empty. not even a sketchup structure file, just 0
So unless you’re making your own backups, might be time to restart your work.
and make versions. from time to time, save as. that way you can return to a previous step.
I understand, thank you very much for taking the time my friend.
Hello! Could you help me with mine? It was working normally, I saved the project, and then a power outage restarted my laptop. When I try to open it, I get the same message, and I can’t find a solution.
Your file contains nothing but zeroes. There’s nothing to recover.
Are you using a cr acked version of SketchUp 2024? Where are you saving the file while working on it? Did you experience a power failure while working on it?
