How do i put an option in a dynamic component to create a row of items between two specific distance of edge off an object
For this is there a way i can make the spacing stay as close to 300mm between the holes as possible depending on the size of my rectangle
The hole cutter component needs to be inside a second hole cutter for copies to cut the surface, so have two sets, one on bottom surface and another on top that includes the rim.
First try to achieve this hole cutting technique
copies of holes.skp (37.2 KB)
this may help
Then find the max number of holes for given length and remainder
Decide whether to divide (average), start, finish positions
