Hi SKP-Community,
i want to generate reports with SKP 2019.
The report should get the infos also from “dyn. components”,
i want to have all info, depending to the axis of my dyn. component.
Lenght = X-Axis of dyn. component
Area = XZ-Axis of dyn. component
Volume = XYZ of dyn. component
Areas and Volumes as: gross and net!
volume gross = volume of the bounding box (is doable with formula “=lenXlenYlenZ”)
volume net = volume like SKP shows in element info box (object without holes, subtractions)
area gross = area XZ relative to the bounding box
area net = area SKP shows, if you click on a face
is there a formula to calculate the (net) volume/area of an dyn. component with holes/subtractions?
i can’t calculate “=lenxlenylenz” for volume, because the holes/subtractions of the
dyn. component aren’ considered with this formula.
maybe i can get the (net) volume from there (via formula).
like: e.g. =volumeobject or =areaobject
i’m also interested in a formula for the (net) area of an object
directed in XZ (to component axis).
Is something possible?
Greetings
Toby
