You know how sketchup uses straight lines to make curves, arcs, circles etc… if i have a section of a ‘curve’ and i want to add increments so that it actually is a curve (for laser/CNC) How best to go about it?
This is to to do retrospectively… i guess i could re-draw with more sections, but surely there is an easier way than this?
Hi Barry
I have used this workflow in the past for exporting to cnc.
If you save out the file as 3d dxf (NOT 2d) then a proper vector gets produced along with the faceted SketchUp ‘arc/circle’. If you the delete the faceted element it should be good for cnc. Please let me know if this works for you as I’ve only used it a few times as an export to Rhino.
Best regards
Dan
Dan’s suggestion of exporting as a 3D DXF file is important no matter how many segments your curves are made of. Still, if you want to make them appear more smooth in SketchUp, Fredo6’s Curvizard has a tool to do that.
Thanks @ DaveR - i did try that extension but couldnt find an option that actually let me ‘up’ the amount of segments… ? Probably user error… seems best option is just to redraw the parts but with higher segment count from the outset.
Got it now… thanks! @DaveR
Much appreciate ![]()
