Copy a component and rename
The top and the bottom of a box are slightly different. I can create one and make it a component, (Top). I can even give the copy a different name (Bottom). But editing one component also makes the same change on the other.
How can I edit one or both without affecting the other?
Thanks.
Right click on one and select Make Unique.
Thanks a bunch!!! :grinning: :grinning: :grinning:
You can select more than one and make them unique, then that selection will be linked, without disturbing the original or originals.
So if you had 8 components you could select four and make unique giving you two sets of four.
