Converting IFC SketchUp to native Tekla
Hello Everyone,
I’m looking for information on How Convert ifc sketchup to native TRIMBLE TEKLA ?
Is there a good way to do it ?
Maybe a solution with DC or Aerilius’s Attribute inspector ?
If you have Tips, i’m interested
Thanks a lot
David
Perhaps Tekla products have a SketchUp importer ?
Have you checked Trimble Connect features?
Thank you Dan for your answer.
Tekla has a *.skp import format but it doesn’t convert into NATIVE TEKLA (just creating article object).
I can import *.skp as Reference model with TEKLA with both TS and Trimble connect) … my problem is just for converting my SU creation for working with TEKLA.
Thanks again
Have you tried to export to IFC from SketchUp and to import that into Tekla? It would perhaps work best if you added the correct IFC classifications to your SketchUp objects first - otherwise everything will just become “IFC_building_object_proxy” (if I remember right)
Generally speaking, converting between BIM applications via IFC or other format usually doesn’t result in good, usable/modifiable native objects. However, I have got quite well behaving steel structures by importing an IFC created in Tekla into Archicad. Haven’t tried modifying them, though.
Yes, of course :wink: … with IFCBEAM, COLUMN, …
But no … the *.skp import is ok as item and as reference model … but as there’s just surface geometry, tekla can’t undersant that an IPE 360 created With SU is the same than TEKLA’s BEAM IPE 360 …
I have tried to search information about how to do mapping between TEKLA and SU … without good results
and i’ve contacted TEKLA support … but with no more chance.
… so … thanks for your answer, i’ll continue my search :wink:
As it happens, I’m spending the week with my Tekla colleagues this week in Helsinki. Among the set of things we’re working on is the data exchange between SketchUp and Tekla Structures. So any thoughts you have about how this should work would be timely and welcome.
Broadly speaking, IFC is not typically used by any modeling tool as a means for editable data exchange; instead, IFC is a ‘destination’ format appropriate for use as a reference in other modeling applications. Consequently, when you place a SketchUp model in Tekla Structures, it cannot (easily) be edited further.
It sounds like you were hoping there would be a way to place a piece of steel in your SketchUp model and have that automatically be recognized as a piece of steel in Tekla? Can you talk more about the workflow you’d like to be able to follow?
john
SketchUp’s ifc export is outdated and won’t work.
(Import is also outdated)
Use the ifc manager to export
https://www.bimloket.nl/upload/documents/downloads/BIMbasisILS/ILS_Native_SketchUp_v2.1%20ENG.PDF
Thank you John for your Answer,
I (really) hope you will find a top solution for you … and me :wink:
I’m just trying thing with several softwares inluding TEKLA and Sketchup (that i love since a long time).
I can do thiings with SU, easyer than with Tekla (e.g Things that we can do quickly with profil Builder or Shape Bender … that are difficult to do with TEKLA … for example) …
The only thing i can do at the moment ton contournate the problem is, exporting from SU as IFCPLATE, changing it in TEKLA … but it’s fastidious and the axes are moving from face to rear, top to bottom … so it’s not the best way to generalize it in a forkflow…
We stay in touch if you want.
Thanks
And Thank you Jack,
I’ll read you link with attention :wink:
@MikeWayzovski ikeWayzovski
I’m back after a quick test SU to TEKLA.
The structure BUILDING > STOREY > ELEMENT is ok … like in SU but quickly …
but what about the properties of the elements ?
Is it possible to add attributes so that Tekla Can undersant that an IPE 400 is a IPE 400.
In my test, i have the same issue that before … and my IPE become an element with the bounding box dimension :s …
@jbacus
i suppose you know this but … it’s something that can be done really quickly with SU than TEKLA (or impossible …)
Are you enjoying the weather? :rofl:
(I am not a great fan of winter but a slightly frosty weather with sunshine would be preferable to a 4-month November)
That is of course what every BIM user dreams of, but I am afraid it isn’t going to happen soon. Even the major packages like Revit and Archicad don’t talk too well to each other (there are basic differences, Revit using solid geometry and Archicad faces).
Hard but no impossible … with mapping for example
possible with TEKLA, BOCAD, REVIT, CADWORK but not easy nor perfect … (and SKETCHUP ?)
@jbacus
@Anssi
If you’re interrested, here is a link on TEKLA’s website (it’s about Defining the settings for profile mapping of IFC objects)
https://teklastructures.support.tekla.com/sv/201/en/int_defining_profile_mapping_settings_of_ifc
Have a nice day
Make SketchUp respect “true” solide objects (only front faces outward) plus the ability to give these objects an extra material attribute to mimic being a true solide. Nobody is going to know, nor the converter program, that SketchUp is “just” a surface modeler in this regard. It’s only an extra check in SketchUp on SketchUp Solide Objects and the acceptance of an extra attribute, say steel or brass or wood or whatever material.
SketchUp already does this. Solid groups and components export as solids to DWG/DXF. The other available export formats, including IFC, do not support solids.
Thanks for all your post… And about Aerilius’s Attribute inspector ? Someone use it?
For now, only attributes of Dynamic components (library), IFC classifications and advanced attributes are are natively exported ( not correctly, though)
You can edit and add, but it is not coming out. So while they could be usefull inside SketchUp, other software has no direct access to them.
We need clear guidance how to add universal libraries to Objects and how to export them correctly.
Meanwhile, the IFC is constantly developing and SketchUp needs to keep up with them, or it will loose contact with the aec-industry
@jbacus
HI John and everyone
Just to tell you that I’ve posted another subject… For your discussions with your colleagues
Thanks
David
What if Profile Builder could export to an editable Tekla format? Would that be useful to you? Sounds you are already using PB for structural modelling in SketchUp.
Hi Dale, when can I test it !? :grin:
@Whaat
. Do you think that would be possible? Yes, it could be useful for me…
