Context Menus - Can there be too many?
I now have quite a few different assembly types associated with my wall plugin, and unfortunately I am thinking about adding another one. For each assembly type I am creating context menus in my initial plugin load routine/method. The current list of context menus created is given below:
	# Add Context Menus for Editing Wall, Door and Window Assemblies
	unless file_loaded?(File.basename(__FILE__))
		UI.add_context_menu_handler do |context_menu_medeek1|
			if Sketchup.active_model.selection[0].respond_to? :name
  			if Sketchup.active_model.selection[0].name.include?('RECT_WALL_ASSEMBLY_')
				# context_menu_medeek1.add_separator
    				context_menu_medeek1.add_item("Edit Wall Assembly") {
					Sketchup.load(File.join(THIS_DIR,"MEDEEK_RECTANGULAR_WALL"))
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.rect_wall_edit_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek1.add_item("Regen Wall Assembly") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.rect_wall_regen_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek1.add_item("2D") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.rect_wall_3D_2D_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek1.add_item("3D (No Framing)") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.rect_wall_2D_3D_menu pluginversion, pluginserial, pluginlang, "NO"
				if pluginserial != "LT"
					context_menu_medeek1.add_item("3D (Full Framing)") {
						Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.rect_wall_2D_3D_menu pluginversion, pluginserial, pluginlang, "YES"
				end
				context_menu_medeek1.add_item("CMU") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.rect_wall_2D_3D_menu pluginversion, pluginserial, pluginlang, "CMU"
  			end
			end
		end
		UI.add_context_menu_handler do |context_menu_medeek2|
  			if Sketchup.active_model.selection[0].name.include?('GABLE_WALL_ASSEMBLY_')
				# context_menu_medeek2.add_separator
    				context_menu_medeek2.add_item("Edit Gable Wall Assembly") {
					Sketchup.load(File.join(THIS_DIR,"MEDEEK_GABLE_WALL"))
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.gable_wall_edit_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek2.add_item("Regen Wall Assembly") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.gable_wall_regen_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek2.add_item("2D") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.gable_wall_3D_2D_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek2.add_item("3D (No Framing)") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.gable_wall_2D_3D_menu pluginversion, pluginserial, pluginlang, "NO"
					context_menu_medeek2.add_item("3D (Full Framing)") {
						Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.gable_wall_2D_3D_menu pluginversion, pluginserial, pluginlang, "YES"
				end
				context_menu_medeek2.add_item("CMU") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.gable_wall_2D_3D_menu pluginversion, pluginserial, pluginlang, "CMU"
  			end
			end
		end
		UI.add_context_menu_handler do |context_menu_medeek5|
  			if Sketchup.active_model.selection[0].name.include?('SHED_WALL_ASSEMBLY_')
				# context_menu_medeek5.add_separator
    				context_menu_medeek5.add_item("Edit Shed Wall Assembly") {
					Sketchup.load(File.join(THIS_DIR,"MEDEEK_SHED_WALL"))
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.shed_wall_edit_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek5.add_item("Regen Wall Assembly") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.shed_wall_regen_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek5.add_item("2D") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.shed_wall_3D_2D_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek5.add_item("3D (No Framing)") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.shed_wall_2D_3D_menu pluginversion, pluginserial, pluginlang, "NO"
					context_menu_medeek5.add_item("3D (Full Framing)") {
						Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.shed_wall_2D_3D_menu pluginversion, pluginserial, pluginlang, "YES"
				end
				context_menu_medeek5.add_item("CMU") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.shed_wall_2D_3D_menu pluginversion, pluginserial, pluginlang, "CMU"
  			end
			end
		end
		# Add Context Menus for Editing Beam Assemblies
		UI.add_context_menu_handler do |context_menu_medeek3|
  			if Sketchup.active_model.selection[0].name.include?('BEAM_ASSEMBLY_')
				# context_menu_medeek3.add_separator
    				context_menu_medeek3.add_item("Edit Beam Assembly") {
					Sketchup.load(File.join(THIS_DIR,"MEDEEK_BEAM_TOOLS"))
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.beam_edit_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek3.add_item("Regen Beam Assembly") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.beam_regen_menu pluginversion, pluginserial, pluginlang
  			end
			end
		end
		# Add Context Menus for Editing Post Assemblies
  			if Sketchup.active_model.selection[0].name.include?('POST_ASSEMBLY_')
    				context_menu_medeek3.add_item("Edit Post Assembly") {
					Sketchup.load(File.join(THIS_DIR,"MEDEEK_POST_TOOLS"))
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.post_edit_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek3.add_item("Regen Post Assembly") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.post_regen_menu pluginversion, pluginserial, pluginlang
  			end
			end
		end
		# Add Context Menus for Editing Stair Assemblies
		UI.add_context_menu_handler do |context_menu_medeek4|
  			if Sketchup.active_model.selection[0].name.include?('STAIR_ASSEMBLY_')
				# context_menu_medeek4.add_separator
    				context_menu_medeek4.add_item("Edit Stair Assembly") {
					Sketchup.load(File.join(THIS_DIR,"MEDEEK_STAIR_TOOLS"))
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.stair_edit_menu pluginversion, pluginserial, pluginlang
				context_menu_medeek4.add_item("Regen Stair Assembly") {
					Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.stair_regen_menu pluginversion, pluginserial, pluginlang
  			end
			end
		end
My concern is that adding all of these context menu handlers will slow down the performance of SketchUp or the model. However, I haven’t noticed any significant problems to date even with what I have so far. Just looking for some guidance or what would be considered best practice in this regard.
I would think that context menu handler blocks are only executed when the user clicks the right-mouse button, or opens the Edit menu’s context submenu.
Consider creating a submenu if your extension’s menu item count is very large.
Fair enough, that should not slow down SketchUp then (until you right click on something).
What exactly is the Edit Menu’s context submenu?
Open SketchUp, insert a component.
Right click it and view the context menu.
Then compare to the context submenu at the bottom of the Edit menu.
Select a primitive (edge or face,) repeat compare.
Okay wow, I didn’t even know the Edit menu did that.
It does this I think so that users can create shortcuts to context commands through the Preferences dialog.
