Prompted by a question (over at SCF,) about using a SystemExit exception (fired by exit(),) to bail out of an input handling routine.
The main answer is: I know of no good use for exit() in an embedded Ruby subprocess.
… and a better solution is to use custom exception subclasses (usually of RuntimeError.)
Custom_Exception_SubClasses.rb (1.8 KB)
# encoding : UTF-8
# A simple example of creating your own Exception
# sub-classes inside your own namespace modules.
# fail() is an alias for raise(), and most coding style guides
# prefer that fail() is used when first causing an exception,
# and raise() is used when re-raising a current exception within
# a rescue block.
module Author # <--<<< Change to unique toplevel namespace module.
module SomeParticularPlugin
VERSION = '1.0.0'
InputCancellation = Class.new(RuntimeError)
InvalidSelection = Class.new(RuntimeError)
NoGroupsSelected = Class.new(RuntimeError)
# In this module we assume that the module variables: @@prompts,
# @@defaults, @@choices & @@caption have already been defined.
def get_input(selection_set)
# First, make a decision about the selection set:
if selection_set.empty?
fail(InvalidSelection,"selection is empty!")
elsif !selection_set.single_object?
fail(InvalidSelection,"selection not single object!")
else
grps = selection_set.grep(Sketchup::Group)
if grps.empty?
fail(NoGroupsSelected,"no groups are selected!")
end
end
data = inputbox(@@prompts,@@defaults,@@choices,@@caption)
# false if the user cancels
fail(InputCancellation,"user cancelled") if !data
# otherwise data is an array of values
rescue InputCancellation => err
UI.messagebox("Stop: #{err.message}")
return nil
rescue InvalidSelection => err
UI.messagebox("Selection Error: #{err.message}")
return false
rescue => err # any other exception
# recover gracefully
UI.messagebox("Error: #{err.message}")
return false
else # no errors
# code to execute when input is valid
return data
end ###
end # specific plugin module
end # outermost namespace module
