Closing lines to create a triangular face with vertices in diferent positions
Are there any easy way or a plugin that allows me to create a face like the one I marked in red. The vertices are in different positions so I’m
having such a headache doing this.
Nothing posted!
I updated
Eneroth face creator will create any faces that can be
Normally, redrawing any of these 3 lines should make a face. because a face is minimum 3 coplanar lines.
If it doesn’t work, it might be that one of your 3 lines is actually not one but more segments. Maybe you have a slight inflexion somewhere, of a 10th of a degree, but SU will see it a two lines, and you’ll loose the coplanar thing.
Could you share the 3d model with us, so we can dig in and check ? (either here, by dragging it into the text window, or through wetransfer / any drive really)
This, especially if one of your line is actually broken in two or more and it’s not obvious, this can be very frustrating.
