I want to chagne group axis like pic (left → right)
and I used this method(in following code) but didn’t work
Can you help me for it?
edge = group2.entities.add_line(start_point, end_point)
xaxis = end_point.vector_to(start_point)
zaxis = end_point.vector_to(start_point) * yaxis
yaxis = end_point.vector_to(start_point) * zaxis
transform = Geom::Transformation.axes(start_point, xaxis, yaxis, zaxis)
my_group = group2.definition
my_group.instances.each{ | instance | instance.transform!(transform)}
my_group.entities.transform_entities(transform.inverse, my_group.entities.to_a)
↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓full code↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓
require 'sketchup.rb'
module Chromite
def self.makebox
model = Sketchup.active_model
entities = model.active_entities
selection = model.selection
faces = selection.grep(Sketchup::Face)
faces.each{|face|
group = entities.add_group(face)
group2 = group.copy
group.explode
entities2 = group2.entities
before = entities2.grep(Sketchup::Face)
before[0].material = [50, 255, 255]
before[0].pushpull( 10.mm )
new_faces = entities2.grep(Sketchup::Face) - before
upper_face = new_faces.find {|f| f.normal == before[0].normal.reverse }
unless upper_face.nil?
start_point = upper_face.bounds.center
offset_vector = upper_face.normal
offset_vector.length = 90.mm
end_point = start_point.offset(offset_vector)
end
layer = Sketchup.active_model.layers.add("win")
my_group.layer = layer
entities2.each{|e| e.layer = layer }
if !model.active_path.nil?
instance = model.active_path.last
definition = instance.definition
my_group_copy = my_group.parent.parent.parent.entities.add_instance(my_group.definition,my_group.transformation)
my_group.erase!
end
end
if( not file_loaded?("kce_makewin2.rb") )
UI.menu("Plugins").add_item("Start makewin Tool2") { self.makebox }
dir = Sketchup.find_support_file("Plugins")
cmd = UI::Command.new("Start makewin Tool2") { self.makebox }
cmd.large_icon = cmd.small_icon = dir+"/kce_makewin2.png"
cmd.status_bar_text = cmd.tooltip = "Tool2 for making kce daylight analysis window"
tb = UI::Toolbar.new("Poké Ball™")
tb.add_item cmd
tb.show if tb.get_last_state == -1
end
file_loaded("kce_makewin2.rb")
end # of chromite class
