Changing the axis of a group/component is possible applying a transformations. You need to transform its definition content, then the instance(s) with the inverse transform. There are many topic about this in this forum. Search for it.
One example:
i have try modif your code, but that is not work.
def create_group_and_transform_study
model = Sketchup.active_model
enta = model.active_entities
sel = model.selection
group1 = sel[0]
faces = group1.entities.grep(Sketchup::Face)
face1 = nil
faces.each{|e|
y =e.normal.y
if y==-1
e.material="red"
face1 = e
end
#group1 = enta.add_group
#Just to see the bundig box:
#Sketchup.active_model.selection.add group1
UI.messagebox("Empty group1 created in model origin")
# Create points in model cord. system
#p1m = Geom::Point3d.new(0, 1, 1)
#p2m = Geom::Point3d.new(1, 0, 1)
#p3m = Geom::Point3d.new(1, 2, 2)
#face1 = group1.entities.add_face( p1m, p2m, p3m )
# Get the group1 current transformation
tr_group1 = group1.transformation
# and see the coordinates in group1 cord. system
vert0_posm1 = face1.vertices[0].position
puts "Vertices 0 group1 cord 1st: #{vert0_posm1.to_a}"
puts "Face normal group1 cord 1st: #{face1.normal.to_a}"
# and see the coordinates in model cord. system
vert0_posg1 = face1.vertices[0].position.transform(tr_group1)
puts "Vertices 0 model cord 1st: #{vert0_posg1.to_a}"
puts "Face normal model cord 1st: #{face1.normal.transform(tr_group1).to_a}"
puts
UI.messagebox("Face created in group1.")
# I want the group1 axes origin on one of the face vertices
group_opoint = vert0_posm1
# I want the group1 Z axis parallel to face1 normal
group_z_axis = face1.normal
# Creates a Transformation where origin is the new origin, and zaxis is the z axis.
tr_orig_zax = Geom::Transformation.new(group_opoint, group_z_axis)
# Transform the group1 INSTANCE with this transformation
group1.transform!( tr_orig_zax )
# Get the group1 current transformation 2nd stage
tr_group2 = group1.transformation
vert0_posm2 = face1.vertices[0].position
puts "Vertices 0 group1 cord 2st: #{vert0_posm2.to_a}"
puts "Face normal group1 cord 2st: #{face1.normal.to_a}"
vert0_posg2 = face1.vertices[0].position.transform(tr_group2)
puts "Vertices 0 model cord 2st: #{vert0_posg2.to_a}"
puts "Face normal model cord 2st: #{face1.normal.transform(tr_group2).to_a}"
puts
UI.messagebox("group1 INSTANCE transformed by origin/axes")
# Transform the group1 DEFINICION ENTITIES back with
# this transformation inverse
myentities = group1.definition.entities
myentities.transform_entities(tr_orig_zax.inverse, myentities.to_a)
# Get the group1 current transformation 3rd stage
tr_group3 = group1.transformation
vert0_posm3 = face1.vertices[0].position
puts "Vertices 0 group1 cord 3rd: #{vert0_posm3.to_a}"
puts "Face normal group1 cord 3rd: #{face1.normal.to_a}"
vert0_posg3 = face1.vertices[0].position.transform(tr_group3)
puts "Vertices 0 model cord 3rd: #{vert0_posg3.to_a}"
puts "Face normal model cord 3rd: #{face1.normal.transform(tr_group3).to_a}"
puts
UI.messagebox("group1 DEFINICION ENTITIES transformed 'back' by origin/axes")
return "Do you see?"
end
