Can't select axes
Hello,
I have a couple red-green-blue axes I can’t seem to delete–I think I forgot to delete them when I downloaded components from the 3D Warehouse. I would like to delete them but can’t select them. I’ve tried scrolling through my Outliner to see if they get highlighted but that hasn’t worked. I’ve tried delete guides, hiding axes. The one that has a blue X beside the green and red is the most persisent. Any help appreciated, thank you!
You can’t delete axes unless you explode the objects to raw geometry which isn’t a good idea. Every group or component will have its own axes. You shouldn’t see those axes if you exit the edit mode for the object you have open for editing.
The axis with the “blue X” indicates the component has gluing properties set.
