build a model, now I can’t find it? help
the file shows in my quick access but when I try to open it said does not exist?Help.
thank you
Stella Barison
When you open SketchUp, do you always get a prompt to open the autosave file instead?
An autosave file with the same name as you have given with ‘Autosave_’ added is generated each time when SketchUp stops abrubtively.
Do not use USB-drives as save location, use the local harddrive or desktop and when done, copy it to the USB.
Might be that the last autosave is the one you are looking for? The one with the most Autosave_…
Autosave_Autosave_Autosave_Autosave_Autosave_Autosave_Autosave_Autosave_
Something is not right.
