I definitely think you’d be better off not starting by drawing the thing you want to draw; draw something simpler instead, to get used to the user interface
Go to WINDOW menu >> PREFERENCES. In there go to DRAWING and ensure hat “click-move-click” is enabled rather than autodetect or click-drag-release
Now, point to ANY icon that is a tool (like the arrow, paint bucket, hand etc) and right clic. Ensure LARGE TOOL SET is ticked. That gets you the Pie Tool and others
Now, let’s just start with a rectangle - choose the rectangle tool, click the mouse in the drawing area and release the mouse button. now move the mouse and see the rectangle appear. It doesn’t matter whether you click again to stop drawing or not, but just type on the keyboard the following keys: 2 4 , 4 8 RETURN
You’ll see 24,48 appear in the dims box in the bottom left as you type. When you press return, the rectangle snaps to be 2 ft by 4 ft
Now find the PushPull tool (cuboid with an up arrow, remember to hover your mouse over the tools to see the names until you are familiar with them - or push the P key), point your mouse at the rectangle, see that it goes blue indicating it is selected to be push/pulled… Click the mouse, move it some way and click again. You made a cuboid. Type 72 RETURN on the keyboard and now you have a 2ft x 4ft x 6ft cuboid
Draw a diagonal line from corner to corner on one face: choose LINE tool or push L, point the mouse at one corner, until a dot appears “stuck” to the corner - this indicates sketchup has snapped its attention to that corner. Cick and release. Move the mouse to the diagonally opposite corner, see the dot appear indicating SU attention has snapped to the opposite corner, and click-release again. Use the eraser tool to erase the line you just drew
This snapping thing is important. You should always try and draw things relative to something else because you’re using a 2D screen to play with a 3D world. You should always try to write the dimensions of everything into the dims box, then you don’t have any “approximately 24 inches” problems
Let’s turn your cuboid into an ordinary table. Select the pushpull tool. Press Ctrl-T (this ensures nothing is selected - so much to tell a newbie, even things like understanding how selection works is complex - some tools operate on already-selected things, some tools select things when you point to them. if ever it seems that you’re interacting with the wrong part of the model, press ESC [stops doing whatever you’re doing] followed by Ctrl-T [deselect all])
Now point at the cuboid face that is 4ftx6ft - it goes blue. Click and move the mouse to squash the cuboid down again. Remember that the direction you’re now pushing is the 24 inch direction, and suppose you want a table top 2 inches thick - so type 22 RETURN (24 inches already, squished down by 22 inches, is 2 inches thick cuboid)
Now grab your tape tool, point to the long edge of the table, click, move towards the middle of the table, type 2 RETURN. A guide line should appear, in dots, set in 2 inches from the table edge. Repeat the process for the remaining sides. Now with the rectangle tool, point in each corner where guide lines cross, click-move(towards the table centre)-click, type 4 , 4 RETURN . repeat for the other 3 corners
Grab the pushpull tool and pull one of these little squares out by 36 inches (click, move as to pull out, type 3 6 RETURN. Point to the other 3 squares in turn and double click. Pushpull will extrude the same distance as last time
You should now have a 4x6ft table, with 36 inch legs, 4x4 inches. I’ve linked a video of me doing this. In the video I also then group, rotate, and reposition what I drew. It doesn’t take as long as you think (certainly less time than it takes to read) when you know what you want to do and how to do it
Hopefully also you’ve learned the importance of: snapping, selecting, click-move-click, pushpull and typing exact dimensions in. Also in the vid, though not obvious is the importance of where you grab an object by, before you start moving it, because it’s that point that will “snap” to other things in the world. If you want to place a chair on a floor surface, grab it by the bottom most corner of one of the legs, don’t grab it by the seat otherwise it’ll sink into the floor! ALl these things and more are covered in the official SU tutorial videos - she speaks slowly and clearly and doesn’t do any magic
