C API or RUBY API
Hi all,
I need to export the outliner (the tree) of component and group with tag with API.
Is C faster than Ruby ?
Is C able to read attribute and length of entities ?
Thanks for your answer
Yes. C code is compiled. Ruby code is interpreted at runtime.
Yes. See the online C API docs …
Yes, but it might not be significantly faster. The SketchUp API is a thin layer on top of our C/C++ source, so in many cases depending on use-case it won’t be noticeable for the end user because Ruby would be fast enough. The development time and maintenance is significantly higher in C than Ruby.
The following topic is about creating a scene graph using SketchUp Ruby …
Thanks , I have already done an serializer in ruby, but it’s quite slow.
Before diving into C/C++ coding, use a profiler and get hard data on your specific scenario. The profiler has always yielded surprising results for me. Revealing areas I didn’t expect to be expensive and places where performance gains can be made from caching computations. (I’ve made a lot of speed optimisations in my pure Ruby extensions by effective caching, but you need to measure.)
SketchUp/speedup: Profiling tool for SketchUp Ruby extensions. (github.com)
Ok I will try to use profiling
