Please add function input ±*/, if this function added, I can scale circle DN600 to DN500 input 500/600, also scale circle DN500 to DN600 input 600/500, this can instead input long number, before I get a long number I had to compute it in another calculator, waste lots of time.
You don’t have to use the scale factor if you know the size you want it to be. If you include the units, it scales to the given value instead of calculating a factor.
I forgot how to calculate since I started working with SketchUp.
Grab the right handle and type ‘600mm’
I want the fuction±*/, scale a cirle is a example one of many, you man scale a component and many other things you must compute is on a caculator, and input number one by one I think that is low process.
