A sneak peek of my upcoming extension, Orienter Express
WOW - you like youre having fun!
cant think what I’m going to do with it, but i want it!
Seriously?! Is that true in general? I didn’t know there was anything you could do.
Thank you for the feedback, Mac users! The extension is marked now as Mac OSX compatible. Greetings!
I believe there is a bug for the copies to local origin, getting more than required
Thank you for the heads up, I can replicate the bug. I’ll keep you updated.
EDIT: Not a bug, there is no duplication. There is a copy of the component on the horizontal edges at one of its vertices and another copy of the component on the vertical edges at one of its vertices. There’s 12 edges and 12 component copies, as expected.
It’s possible to get a better understanding of the answer by using a longer component, like this:
I was trying to insert corners, the first button got me closer to what I wanted to achieve, whereas the last required more work
maybe you could consider an extra one that can do, plus is possible to insert redraw?
At this moment, Vertex Placement just makes copies of the component at the vertext using the same orientation as the original. I hope to implement some kind of better orientation in a future release, but I have to figure how to. Thank you for the video, it was very illustrative.
express.skp (44.8 KB)
The file
Hi Colin,
Yes, it works! While at it I did the same with the SketchupPlus toolbars and it worked too! Perhaps this the fix for all “mute” toolbars.
Edson
Hi Colin,
Edson
Hmmm finally tried it, it’s nice.
only trouble I’m getting, the toolbar is… weird.
uninstalled / reinstalled, relaunched, it’s no avail
I’m on a mac, last osX (13.4) and last version of SU23
Capture d’écran 2023-06-04 à 23.57.23
button 1,2 and 4 and identical. I noticed when I needed 4.
I haven’t noticed that. @alsomar it seems that 2 icons (the pdf ones) have more than one page inside them.
Ooops, that’s why! I’ll fix that, thank you for the heads up!
I’ve just uploaded an RBZ file to my GitHub, so this one should fix the icons on Mac:
I downloaded it on github, but for some reason, SU isn’t interested in installing it.
It’s monday morning, I have other cats to skin, I just took 2 min and deleted the extra pages in the pair of pdfs :smiley:
Capture d’écran 2023-06-05 à 10.22.29
thanks for the quick fix anyway :slight_smile:
The extension update is also available on the Extension Warehouse. Hope it helps!
Gracias por la extensión
