I use sketchup 2015
I saw this error how to solve ?please help
you would need to remove the ‘Beam Tool’ extension and instal an updated version…
did you copy plugins from v13 or earlier?
many will break in v14/15/16 as they use a different version of ruby…
john
The Win32API.so file is now included with SketchUp 2014 and later. It should be loaded from SketchUp’s "Tools/RubyStdLib" sub-folder, not the plugin’s sub-folder.
@DanRathbun
I use free version SkectchUp 2015
I can’t fine RubyStdLib in tools
Can you explain more?
You say you do not have C:\Program Files\SketchUp\SketchUp 2015\Tools\RubyStdLib subfolder - but clearly you do as it’s referenced in your error-message.
It’s the same in Make [free] or Pro.
As Dan says that subfolder now includes that .so file’s code - which is needed by this tool [and that shipped .so should also automatically suit your Win-OS - 32/64bit]
This ‘Beam’ tool is either out of date and therefore just not suited for >= v2014 - whatever you do - or if it has been updated, then get its latest RBZ and install that latest version…
A simple update to this plugin is to do this test:
if Sketchup.version.to_i < 14
### use old .so from the ../Plugins/BeamTool subfolder
load "BeamTool/Win32API.so"
else
### use the code that is now shipped with newer SketchUp's
require "Win32API"
end
So it this plugin is no longer supported/getting updated then you could attempt editing it using Notepad++.exe for your own private use…
Note it’s round line #192 - as the error-message indicated
Thanks a lot I try it now
