Ok thank you
A post was split to a new topic: How do I change Segments of a circle?
In my experience, you only have to change the drawn circle just a little bit, before it the chosen number of segments is unchangeable.
For example, draw 24segment circle, push pull to create cylinder, you can no longer adjust the number of segs at that point.
So for me in my situation!.. (i have a pretty nice looking cylindrical building) but it has only 24 segments
i was always aware that it looked a little low-res back when I started it 5months ago. But I just assumed iād be able to change it later on down the lineā¦
might be out of luckā¦
Thatās a great example of where assuming something makes trouble down the road. Planning ahead is always a good idea. And learning what you can and canāt do before youāre in too deep helps to prevent problems, too.
You need to edit the curve and change the number in the Measurements window. Right click on the link curve, select edit classic Bezier curve.
