Hij is my LenY not showing the right value?
Dakpannen.skp (6.8 MB)
If you want to make use of a Set, treat is as a row with a fixed begin(pan) and end(pan).
The number of pan’s in between can be different, there is a maximum and minimum, depending on the type:
Once you have the set working, start adding copies of the set itself, or combine the set(component) in a new component together with a similar for the Nok:)
SetDakpannen.skp (270,1 KB)
I haven’t taken in account the total length of the copies, but you get the idea…
In your example, the copies of the differen components are mixed up, somehow, resulting in a wrong number of dakpannen.
Thanks! Bedankt!
I will try this asap.
