I found miss some file , colladainheritancemanager.h …/…/common/colladafile.h “./colladatexturehelper.h”“…/…/common/colladageomutils.h”
how can I find them
The SDK does not contain a “skp2dae” example in the "samples"
subdirectory.
(1) Where did you get such an example ?
(2) Are you trying to hack SketchUp’s "Exporters/skp2dae.dll"
library for standalone use ?
You are right 。SDK not contions them 。it develop by one my parterner . I find skp_to_xml in sdk how can I develop a plugin to skp to dae。Could you have any advices ? I
see skp2dae.dll in SketchUp 2024. how can I use it ?
Take a look at this example for a KMZ exporter.
and Dan’s comments here
Is this plugin going to run within SketchUp ?
I test。It work well at skp2xml.dll 。but not work at skp2dae.dll。
main.txt (2.0 KB)
without SketchUp. I want use Exporters/skp2dae.dll standalone .
As I said in the StackOverflow posting linked, it is most likely that you cannot use "skp2dae.dll"
outside of SketchUp. It is an internal exporter interface using SketchUp application code.
I do not know what "skp2xml.dll"
is. It is not an internal Trimble exporter.
