The only thing I found close is InputPoint#instance_path, but it works only based on x,y coords which I think may return wrong results if the point that is used is shared by several instances
Using Make 2017
Using Make 2017
Every ComponentInstance / Group is contained in a parent ComponentDefinition (there is not a single parent instance, but all instances of the parent component definiition). If the parent is a Model, it has no further parent but it is the root.
The nested component instance hierarchy forms a tree. You can obtain possible instance paths by a recursive bottom-up search (from the leaves to root):
def collect_occurences(instance)
instance_paths = []
queue = [ [instance] ] # Queue containing the instance path of the leaf
until queue.empty?
path = *(queue.shift)
outer = path.first
# Parent is root: instance path is complete.
if outer.parent.is_a?(Sketchup::Model)
instance_paths << path
# Parent is component definition:
# Prepend preliminary instance path by all instances of parent ("brothers of father").
else
outer.parent.instances.each{ |uncle|
queue << [uncle] + path
end
end
return instance_paths
end
instance_paths = collect_occurences(some_instance)
As Andreas mentions, given an arbitrary instance or definition you cannot find a single path back to the model root. You can only obtain a path when traversing from the root and down the hierarchy.
Can you describe the scenario where you have an instance and you need a full path?
BUT,… if the instance is being edited than you CAN:
This will return any instance that is part of any definition that holds the instance I’m interested in. I need to remove those instances that are not containers of ‘some_instance’
I’m not sure I understand what you are saying. It will return any instance path (array of nested instances) that contain some_instance as the last element (leaf).
