Please post code correctly on the forum:
Yes, it is wrapped inside a JS Object parameter. But each Ruby callback can have it’s own object parameter with a distinct onCompleted function.
Incorrect. You should not make assumptions without evidence.
Of course, it gets called because you added in a rescue clause that trapped the Ruby exception and did not reraise it. So, execution then resumes following the begin … rescue … end block. And since there is nothing else to do, the callback has “completed”.
I think that the onCompleted JS callback can receive the return value from the Ruby-side callback block if you give it a parameter variable. Somewhere ThomThom showed an example of this.
Also, it may be cleaner Ruby if you define a true Ruby method to handle the callback tasks, and then the def acts as the block opener for the rescue clause.
def bom_task(toEmail)
create_bom()
send_bom(toEmail)
rescue => e
puts e.inspect
e.message
else
'Success - BOM created'
def add_callbacks(dialog)
dialog.add_action_callback('bomTask') do |action_context, toEmail|
bom_task(toEmail)
In the JavaScript:
function createBOM() {
sketchup.bomTask(
'argument',
onCompleted: function(result) {
console.log(`The result was: ${result}`);
To see the JS console you need to open the Chrome DevTools. (Right click on the dialog)
So, obviously, if the result gets returned to the JS-side, your JS onCompleted callback function can act conditionally upon the content of the result.
The docs also warn you that the reference for the dialogs should be persistent @vars otherwise the dialog object could go out of scope and get garbage collected … Poof! gone.
