After using the exit_script,
When I try to add_action_callback on html dialog,
Uncaught TypeError: sketchup.dlg_html is not a function error.
can’t I use both?
ruby
model = Sketchup.active_model
selection = model.selection
entities = model.active_entities
dlg_html = File.join(__dir__, 'html', 'test.html')
dialog = UI::HtmlDialog.new(
:dialog_title => "Dialog Example",
:scrollable => true,
:resizable => true,
:width => 600,
:height => 400,
:left => 100,
:top => 100,
:min_width => 50,
:min_height => 50,
:max_width =>1000,
:max_height => 1000,
:style => UI::HtmlDialog::STYLE_DIALOG
dialog.set_file(dlg_html)
dialog.show
UI.messagebox("loading")
dialog.execute_script("var testString = 'test';")
dialog.execute_script("document.getElementById('input_test').value = testString;")
dialog.add_action_callback("dlg_html") {|dialog, data|
puts data
html
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Document</title>
<script type="text/javascript" src="../js/jquery.js"></script>
<script type="text/javascript">
function sendData(flag){
var test_data = document.getElementById("input_test").value;
console.log(test_data);
sketchup.dlg_html(test_data);
// window.close();
</script>
</head>
<body>
<div>
<input type="text" id="input_test" name="input_test">
<input type="button" onclick="sendData();" value="Set" />
</div>
</body>
</html>
Please post Ruby API questions in the Ruby API subcategory.
(EDIT: Thanx @dezmo for topic reassignment.)
Your JS function sendData has an argument that is not sent by the button’s onClick event.
Also this element in the <head> of the HTML document …
… is unnecessary with UI::HtmlDialog which is using the Chrome Embedded Framework.
The following works for me in SketchUp 2017 and 2021.
module Testing
extend self
@dialog = nil if !defined?(@dialog)
def dlg_html
%q[
<!DOCTYPE html>
<html lang="en">
<head>
<!-- <script type="text/javascript" src="../js/jquery.js"></script> -->
function sendData(){
// window.close();
document.onreadystatechange = function () {
if (document.readyState === 'complete') {
sketchup.ready();
</script>
</head>
<body>
<div>
<input type="text" id="input_test" name="input_test" value="nothing">
</div>
</body>
</html>
end
def dialog
#dlg_html = File.join(__dir__, 'html', 'test.html')
# For this test we'll use a method to generate a HTML string.
@dialog = UI::HtmlDialog.new(
:resizable => true,
:width => 600,
:height => 400,
:left => 100,
:top => 100,
:min_width => 50,
:min_height => 50,
:max_width =>1000,
@dialog.add_action_callback("dlg_html") {|_dlg, data|
puts data
@dialog.add_action_callback("ready") {|_dlg|
UI.messagebox("Ready to change value ...")
@dialog.execute_script("var testString = 'test';")
@dialog.execute_script("document.getElementById('input_test').value = testString;")
#@dialog.set_file(dlg_html)
@dialog.set_html(dlg_html())
# Show the dialog window last after setting all callbacks:
@dialog.show
end
end
To test after pasting into the Console, … use the command …
Testing.dialog
