I’m unable to find any format that the free web version will import. Is there a list somewhere of file types that can be imported for free? I’m trying to import a vector PDF ideally but have some flexibility to convert or work around limitations if I know a format that is supported.
Go to the Import panel. It will show you what formats you can import. Vector PDF is not an option nor are CAD file types like .dxf or .dwg. This shows the file types that can be imported with the paid web version.
When I click on “My Device” it takes me to a file browser window which shows the files on my desktop (by default, full filesystem browsing available). Still no mention of supported types, just the text I pasted above showing types available after upgrade.
I’m trying to import a PDF of a site layout that has a scale on it I can use to resize once I get it imported.
If this is for any sort of commercial use you would need a paid subscription to avoid violating the Terms of Use. You could go with the paid web version to start and then definitely you’d be able to import raster images to use as a reference for tracing. If your PDF contains vector line work there are applications like Inkscape that can create .dxf files from vector PDF. You could then import the .dxf file.
Yep JPG imported despite the text implying it would require upgrade. Worked fine just confusing information. This is not for commercial use, it’s for my own personal project. Appreciate the help!
