Hello,
Does anybody recognize the same problem?
The Web viewer doesn’t show any openings created with the following method:
Anybody with a solution?
Did you set the component axis to be in the plane you want the cut to be?
hello,
If you view it through trimble connect, it’ll use trimble connect visualizer which indeed fails to show cut opening components.
You’d better use the “share a link” function that will show your models properly in the sketchup web app instead
with this button :
or file > trimble connect > share a link
I’m not using SketchUp by myself, but i am gonna ask the designers.
Thanks.
I’m gonna try this method. Thanks.
