Vray Error Rendering Animation
I am having the following error when I try to render a basic animation using Vray 4.10.13
The model is a Basic cube with a Section Plane
Test Vray Animation.skp (143.4 KB)
Any help would be greatly appreciated.
Thank you
Hi. In your file you uploaded, there doesn’t seem to be a difference between scene 1 and 2. This means that there is no ‘frame rate’ or frames between the two scenes to render. See test where I was able to export an animation with your file after zooming in and updating scene 2.
Also what version of V-Ray are you using? I’m using the latest version 5.10.04 released May 2021.
@eric-s
