The code example shown in the API docs for the Sketchup::View#load_texture and Sketchup::View#release_texture methods is not a working example and is fragile (will fail with raised exception just after a new model is loaded.)
Here is an working example …
module Example
class MyTool
def activate
view = Sketchup.active_model.active_view
@points = [ [0, 0, 0], [9, 0, 0], [9, 9, 0], [0, 9, 0] ]
@uvs = [ [0, 0, 0], [1, 0, 0], [1, 1, 0], [0, 1, 0] ]
@extents = Sketchup.active_model.bounds.add(@points)
@color = Sketchup::Color.new(0, 0, 255)
matl = view.model.materials.current
# The current material might be nil just after model load.
# Also the current selected material may not have a texture:
if matl && matl.texture
image_rep = matl.texture.image_rep
@texture_id = view.load_texture(image_rep)
else
@texture_id = nil
end
rescue => err
puts err.inspect
ensure
view.invalidate # redraw the view immediately
end
def deactivate(view)
view.release_texture(@texture_id) if @texture_id
view.invalidate # redraw the view when done
end
def draw(view)
view.line_stipple = '' # Solid line
view.drawing_color = @color
if @texture_id
view.draw(GL_QUADS, @points, texture: @texture_id, uvs: @uvs)
else
view.draw(GL_QUADS, @points)
end
end
def getExtents
@extents
end
def onMouseMove(flags, x, y, view)
view.invalidate # redraw the view on mousemove
end
end
end
Sketchup.active_model.select_tool(Example::MyTool.new)
