The release notes for SU16 says:
UI::Command class and UI.create_cursor were modified to accept vector format (SVG under Windows, PDF under OSX). Both toolbars and cursors can now accept vector icons.
So, if I put as set of SVG files and PDF files in an extension’s icon folder, I’m assuming SU will use the correct set based on user environment?
Or do I have to test mac vs windows when assigning Command.large_icon=
you need to test for version and platform…
mac has always accepted PDF as icons…
john
Thanks,
Ideally I could draw my vector icons in SketchUp, but it can’t export to SVG(?)
And SU > pdf puts output on an 8.5x11 page (maybe that will be ignored?)
How do you recommend creating the SVGs?
I set the SU viewport to 512 X 512 then frame the model of the icon I’m wanting and export to pdf with a line weight of 5…
I convert to SVG using a command line tool…
I also save a png…
# to handle the new file formats for toolbar images...
ext = '.png'
ver = Sketchup.version.to_i
if ver >= 16
osx = Sketchup.platform == :platform_osx
ext = osx ? '.pdf' : '.svg'
end
# and at the appropriate place
cmd.large_icon = cmd.small_icon = File.join(path, 'Resources', 'images', "#{NAME}#{ext}")
sine_circle.pdf (16.2 KB)
john
SU export to pdf has “hidden line options”. Where is "line weight of 5?
What command line tool?
I’m on a mac, line weight is an option for 2d export…
pdf2svg is a command line tool I use, but I have never tried the Windows version…
other people just use Inkscape or Illustrator…
john
